Aftermarket head unit without a cd player?
I cant say Ive seen any that aren't pretty hideous with ugly displays, lights, buttons, etc.
Id do my best to upgrade the stock system where possible and chalk the rest up to being in a car. Even Nakamichi, which seems to have the least intrusive designs, often is a bit much.
Good luck.
Originally Posted By: HerrStig
The only way to jam lots of music into a memory of any kind is to compress it, which causes some of the music data to be lost. At some point the compression system does so much to the file folks can hear the difference. Typically, dynamic range and high end suffer the most. In a car you probably won't hear that
That's the thing. In a portable environment, most people don't do any critical listening, so it doesn't matter too much. For car/portable MP3 player duty, I typically encode everything using MP3 VBR2 setting, which results in an average bit rate of around 190 kbps. It cuts off all frequencies above 18.5 kHz. Given my age, my ears can't hear anything above about 17 kHz anyway.
Flash memory is cheap these days. You can get a decent 128 GB USB flash drive for around $30, and you can pack a ton of music on it without having to compress it too much. Just make sure your car deck can actually support this size drives.
Quote:
I'm convinced that stereo reached a high point in the late 70s when the CD came along, outfits like Marantz, Mac, Carver, Technics, KLH and AR were building good analog gear, since then "progress" means smaller and cheaper plastic boxes.
First commercial CD titles and players came out in early 80s, but yes, I agree with you in general.
I could have been clearer. I mean't that there were some really good amps and speakers available by the late 70s which could do the CD's justice.
JHZR2:
There ARE ones that are NOT hideous!!!!
I HAVE one of those.
(and I have VERY strict standards when I say That Pioneer head unit (forget model) looks factory -
Trick is to look hard and take your time, and look at past models that are still available.
Will do asap
here's an old pic, but this is the HU. (It's not lit up and not very large in the pic, but will get a better one with it on soon) IMHO, it's hardly noticeable as an aftermarket HU.
come on! The shiny chrome gives it away instantly even when it is off. When on, I bet it has color scheme which will NOT match the sedate lighting of the original unit.
I have a JVC KDA95BT that is not gaudy with lots of lights and buttons. I don't see how anyone could say it looks out of place in my dash. There are almost no buttons on the face whatsoever, amd the screen has about 30 different color options so it will match any factory dash lighting.
I'm certainly not an audiophile, but I've been pleased with the following H/U
http://www.crutchfield.com/S-LTyiNcitqqp/p_113BT362U/Kenwood-KDC-BT362U.html
This does have a single disc CD player, so you could probably find another unit in the range that doesn't offer the disc.
I bought one for the 99 MGM, replacing the cassette unit and adapater. My 17yo daughter drives that car, so having a unit where her phone connects via bluetooth for both audio and phone was appealing.
The install was easy enough and I liked the BT integration, so I got another for my 03 Protegé5.
I was able to set the color to match the red backlit gauges. The only downside is it's hard to see that color in the day when wearing polarized sunglasses.
Can't complain as it was $99 for the unit, all mounting hardware and the wiring harness that matches the car.
If you have Discover Card cashback bonus, you could use $80 in cashback bonus to get $100 in Crutchfield gift cards to cover the cost.
The thing to remember about ordering from an outfit like Crutchfield is they offer free shipping, no sales tax and up to $50 in installation accessories.
Can't hardly go wrong no matter what you pick.
Originally Posted By: exranger06
The specs say this unit has a front USB port. Where is it? Gotta lower the faceplate to get to it?
I'm not sure where you read it has a front USB input. It doesn't have one. Both USB inputs are rear inputs. It has 45" long wires permanently connected to back of the unit with USB inputs on the ends so you can route them to your glove box or center console. Which IMO is way cleaner and nicer than having a front input. It also has a rear AUX jack.
It was a product description on amazon. I figured they goofed up...
Quote:
Bluetooth Enabled Single-DIN In-Dash Arsenal Series CD Receiver with Front Panel USB/AUX Inputs and Pandora Link
