Any thoughts on how AeroShell W100 (SAE 50) or their W120 would compare to monograde motorcycle oils of the same viscosity?
alarmguy said:4) Piston aircraft engines suffer camshaft failures at very high rates. Hence the product called "Camguard".
No, certain manufacturers have had cam issues, not all.
I do understand the purpose of the aftermarket product called "CAMGUARD" but lets not say every piston aircraft engine maker requires or even suggests it. Cam issues were bad design.
Incorrect. Both major engine manufacturers experience camshaft failures at much higher rates than the automotive industry. Period.
From Aviation Consumer:
"Just as you thought it was finally safe to buy a cylinder, now comes a crisis over camshafts. Specifically, engine shops tell us they're seeing premature wear and failures due to spalling and many also report that cams that used to make it through one TBO run and into another are now too worn to reuse. This trend has actually been brewing for a number of years and no one seems able to say definitively if it's getting better or worse. Opinions bridge the divide. "Definitely worse, in my opinion," says Penn Yan Aero's Bill Middlebrook, who shipped us a couple of scrapped cams to prove the point, along with a couple of spalled lifters. "We had a brand new cam come apart in the test cell—it wiped one lobe," he added. This sort of thing used to be limited to Lycomings, whose cam is mounted higher in the engine core, away from oil misting from the crankcase and in line with blowby from the cylinders. But lately, shops tell us they're seeing more cam-related wear issues in Continental engines, too. TCM seems to have noticed this and in 2005, it issued SID 05-1, a service directive related to cam and tappet wear. And speaking of tappets, some in the industry think that's definitely the problem and a worn cam is the secondary result. "We think the problems definitely start in the lifters, predominantly," says Greg Merrill at Aircraft Specialties Services, a Tulsa house that regrinds and reconditions cams and tappets for many engine shops. His company also developed CamGuard, an anti-wear, anti-corrosion oil additive. "We do see the occasional cam with a bad lobe, but it's rare. It's almost always a problem with the tappets," Merrill adds. What exactly is going on here? Everyone has a theory, so take your pick. Some, like Allen Weiss at Opa Locka, Florida's Certified Engines believe that something changed in the fuel or the oil in the recent past, recent being perhaps in the last 10 years."
Huh? Where are your comments coming from?
Who is comparing camshaft in piston aircraft engines to automotive. I thought we were talking about AreoShell oil not having automotive antiwear additives = ZERO.
Your incorrectly promoting that piston aircraft engine makers have an issue because of this and you are COMPLETLY wrong.
You can cherry pick engines of any maker in the world for any mode of transportation and find one that is having an issue, such as camshaft problems and recommends a product to help solve the issue, such as CamGuard which is STILL free of zinc ect.
Your too jaded for me to comment further, but for the others, the AEROSHELL piston aircraft engine oil is a certified engine oil that major piston aircraft engines require AND DO NOT RECOMMEND ADDING ADDITIVES.
AS far as your reply, below is a cut and past from your post, of the CAMGUARD oil addiitive, did you even read it? Even they say the issue is with the lifters not the cams (but who cares) and AGAIN, go buy a piston aircraft, you will not see the manual calling for CAMGUARD additive, except if its a crappy engine design with issues, but think its been worked out on the new engines.
here I highlighted an area for you from your own darn post! *L*...
""We think the problems definitely start in the lifters, predominantly," says Greg Merrill at Aircraft Specialties Services, a Tulsa house that regrinds and reconditions cams and tappets for many engine shops. His company also developed CamGuard, an anti-wear, anti-corrosion oil additive. "We do see the occasional cam with a bad lobe, but it's rare. It's almost always a problem with the tappets,""
No need for me to look for your reply)
