Originally Posted By: shredguy
All of our post 2010 trucks are DEF required. What sucks is that our 2011 that blew a gasket was a DEF required truck.
I think our high level of idle/PTO operation is definitely adversely affecting our dpf function. Just not sure how to fix it. I guess we could have each driver go for an extra 20 mile drive once a week.
The extra drive will definitely help with the DPF systems. Most SCR (or DEF) systems are tuned to help reduce the need of of the regen cycle which burns out and cleans your DPF. I would also recommend that once a year (or maybe twice) that you have the filter from the DPF pulled, inspected and cleaned. Up here we have seen trucks that spend most of it's time at idle catch fire because of a clogged particulate filter that didn't regen often enough and was never checked. When these systems aren't working properly they can cause other issues, which may be related to your failures.
Also get in touch with your fuel supplier, and check your fuel quality vs the fuel specs issued by the engine manufacturer like this one from cummins. My experience has been that higher cetane fuels and higher BTU from fuel burned means less problems with the emission systems. Also a question to ask about is biodiesel content, detergency and thermal stability of the fuel - these can make a difference in the quality of combustion which can then influence things like fuel dilution.
