I've had a little trouble with my '03 Buick Park Avenue with the N/A 3.8 L engine losing, or burning, oil -- about 1 quart in 1700 miles at present. There doesn't appear to be a leak or any blue smoke, so I'm not sure where it's going. On another thread, posters suggested checking the PCV valve, and possibly Seafoaming the engine. One suggested administering some of the Deep Creep spray into the PCV access tube just to the right of the valve.
The 1-year-old, OEM valve is clean and rattles. I squeezed about an ounce of the liquid Seafoam into that tube opening, with the engine off, then started up and drove the car, getting the revs up, for about 15 minutes. No white smoke that I could see, so maybe it wasn't doing anything, or I hadn't done it right.
Question, then: Must the car be running while I feed in the spray or liquid? I had the engine on at one point, and removing the housing that covers the PCV valve resulted in a lot of sucking/roaring noise, and the engine stumbled. If I have to run this stuff into the running engine, as the instructions have it, I'll need to have a helper keep a foot on the pedal, to keep the revs up, right? Or is there another way to get the stuff into the engine -- and if so, can you point me to a site with some pictures?
TIA,
TIA,
