Additive pack drop out city!
Back in Arizona. Finally
I was changing the oil on the family truckster - a 2002 Chevy Tahoe when something happened that I have never seen before.
I drained the oil, changed the filter and refilled with Mobil 1 5w30 - OK so good. Fire the car off let the engine run, check for leaks & cut her off. My 5.3 V8 takes like 5.75 qts to get to the full dipstick line so I elected to use some old Mobil 1 0w40 from about 3 years ago: a genuine SL/GF3 oil of yore.
I had opened the oil and used it in the lawnmower probably 3 years ago and sealed it back up and, uh kinda forgot about it. It sat on the garage shelf for those three years. Fast forward to today.
Opened that bad boy up and began pouring it into the engine and it looked really dark. Then, I could smell a hypoid like smell. I ceased operations immediatly and checked this stuff out. I poured what was left in the bottle into a clean pan and it was some kinda F'dU!! The bottom of the bottle had a black slime, just a thin layer mind you but none the less really bad looking stuff.
This opened up (but resealed) bottle had endured Houston's humidity and the years of temperature changes while sitting on the garage shelf but quite frankly I was amazed at the transformation.
I dumped the whole crankcase of fresh Mobil 1 and filter (boy does that hurt)and ran a gallon of Mobil's conventional oil through the engine straight into a catch can to flush the engine of that sh!t. New oil and filter and she is good to go but I learned a lesson here: If it's been opened once you better use it up pretty quick or throw it away.
Anybody care to speculate what happened? I'll start with this - I think this bottle of Mobil 1 was near 100% PAO and over the years absorbed moisture and was heat / cold cycled while never being disturbed, thus the add pack fall out. Anybody else got any ideas? Cheers DV
""I think this bottle of M1 was near 100% PAO and over the years absorbed moisture and was heat / cold cycled while never being disturbed, thus the add pack fall out""
that splains it oil like wine should be protected from temp cahnges and moisture.
bruce
So what does this mean for new cars that don't sell and sit in dealer's lots for a year or more? Get the oil changed ASAP?
My gf`s dad had the same thing happen. Had some old oil sitting out in the barn for several years (either Penz or GTX,he uses both on their Olds 88) and one day noticed something weird......there was clear liquid on top,and dark thick liquid the rest of the way down to the bottom.
We've had brand new cars in fleet service that have a build date greater than than a year before we took delivery. By definition it's ready for it's first oil change at less than 100 miles.
I just dumped 2 bottles of 5W30 M1 SJ, 1 of which had been opened, 2 bottles of Mobil Clean 10W30 SJ, 1 bottle of Pennzoil Synthetic 10W30 SJ that was opened and 1 bottle of SJ yellow Pennzoil 5w30. All went into a 5 gallon jug to be recycled. All oils had to be over 7 years old....the M1 seemed a bit dark and smelled a bit funny but did not notice any slime or anything else. The other oils, even the Penn Synthetic looked as nice as if it was brand new
Goose
I don't know if this is right or not, but I would have probebly shook it up good and poured it in. At least it's not Lucus.
I wouldn't have wasted that much oil at all. Maybe run it for a slightly shorter OCI than usual, but I would have got SOME use out of it....
Think 3K OCI's are wasteful - how about this?
I have a couple of opened but re-sealed bottles of oil.
Used in snowblower. None over two years old(opened).
Takes just over half a quart for fill.
It's GC 0W-30, not going to waist it.
Ever oil I have come across does this if it sits for a signifcant amount of time. I never worry about it and have never had problems! I have exspecialy seen this happen back when I used mostly conventional oil.
