1995 F150 with 4.9L inline 6 and 137,000 miles. I boosted this oil with about 2.5 times normal amount of additives (zinc, phos, etc.). First UOA is 40 miles as a baseline. I figured to get it in the engine so any residue that initally soaks into the oil is considered. Second UOA is after total 5000 miles. Not bad considering my previous three OCIs were Iron 472, 124, and 33 after apparently ingesting a lot of construction dust (another UOA thread has the whole gory story). Anyway, if you subtract the baseline, it even looks better as the rise in lead and iron is 19 and 14 over 4960 miles and the other wear metals are negligible. I will continue to run this oil and hope to post another UOA at 9000 or 10000 miles.
I installed 6 quarts of Durablend and 10 oz of 21000 ppm zinc PCMO additive package in July. I added no makeup oil during the 5000 miles represented in the UOA, but since it was then a quart low, I topped it up after pulling the sample.
Parameter 40 miles / 5000 miles
iron 8 / 22
aluminum 8 / 9
lead 11 / 30
copper 9 / 10
silicon 14 / 22
boron 9 / 19
sodium 4 / 9
moly 55 / 51
phos 1939 / 1822
Zinc 2280 / 2089
Calcium 3649 / 2939
mag 276 / 245
All other same but for Cr=2
TBN 12.2 / 10.1
Here are some blotter images to go with the UOA:
Not sure why the second blot is so dark. Sitting on the shelf in front of me it is not nearly that dark.
iron 8 / 22
aluminum 8 / 9
lead 11 / 30
copper 9 / 10
silicon 14 / 22
boron 9 / 19
sodium 4 / 9
moly 55 / 51
phos 1939 / 1822
Zinc 2280 / 2089
Calcium 3649 / 2939
mag 276 / 245
TBN 12.2 / 10.1
