Chevy 1500 Pickup
4.3L V-6
SuperTech ST3980 (PF52 Equivalent)
Pennzoil Long-Life 15w40
Ok, so here's the thing.
Haven't had the truck that long, and it did the same thing with the Purolator filter (PF52 equivalent as well) I had on before.
Say it's 60 degrees out. One day you'll go out and start up the truck. No noise at all...as quite as you could expect. Next day, you go to start it up, and you get the awful "tick-tick-tick" which I presume is "lifter tick".
Now, for the past few days, it's been below freezing both times I have started the truck, around 20F.
Same thing happens here. One day, you'll go out and start her up, and although the engine has a much harder time turning over due to cold temps/thicker oil, you'll get absolutely no noise!! (Which is VERY, VERY sweet considering I'm running a 15w40!)
Next time, it will make a heck of a racket, doing the "tick-tick-tick" thing for a good minute, gradually decreasing in volume.
Can anyone figure out what is causing this behavior?
4.3L V-6
