Let me start off by stating that the filter pictured below was in use for 4 months and nearly 25,000 miles. A bit extreme, hopefully no damage was done to the engine.
pic #1
I cut the base plate off with a dremel and this is what I found. The ADBV is deformed and has wedged itself between the "neck" on the end cap and the base plate. I'm no expert in this area but it looks like oil could easily bypass the filter media since this ADBV seals the dirty side from the clean side. Could this have been a manufacturing defect or was it likely caused during service? Any help or opinions are welcome.
Pic #2
The media appears to be in good condition and I didn't find any large chunks of metal or sludge in it.
Pic #3
The end caps are welded to the center tube which has an unusual array of perforations. It's a very sturdy unit and I can see no way that the media could fail like in the other Amsoil filter failure thread.
Pic #4
The media appears to be about 4" wide by 8' long.
Pic #5
A close up of the media with a bright light underneath it. This was taken after stretching it out on the floor so that's where any debris on the surface came from. I assume the black/red marbeling pattern is from embedded dirt?
I took a sample of the oil[Mobil 1 5w30] and I should have the used oil analysis results by next Thursday or so.
pic #1
Pic #2
Pic #3
Pic #4
Pic #5
