Acetone added to the fuel....
Does the same apply to Xylene and Tolulene;
i.e.; are they just as harmful/corrosive to everything as Acetone is in higher concentrations??
I think they are worse!
E85 has both so it can't be harmful.
E10 98 ---> 10% ethanol and 90% gasoline
isooctane 100
benzene 101
propane 103 ---> LPG component
E85 105 ---> 85% ethanol and 15% gasoline
CNG 107
LPG 108
heptane 108
methanol 113
toluene 114 ---> component of lacquer thinner
ethanol 116 ---> ethylic alcohol
xylene 117 ---> component of lacquer thinner
Originally Posted By: Brit33
I'm bringing up this discussion because I'm interested in testing small amounts of acetone in my carby alfa romeo.
We have such bad fuel here imported from Brazil.
This year has been exceptionally bad.
I;m not interested in getting better mileage.
I'm more interested in improving the quality to avoid detonation and improve idling etc.
my car pings easily even with premium (name used very loosely!) with boosters but tests have revealed both fuels, super and premium, are of equally bad quality.
The boxer is very picky with the fuel and you feel and hear the difference.
But I'm very concerned about the acetone attacking carb parts (diaphragms, o-rings), electric fuel pumps and fuel lines etc.
Thinking of doing some lab tests with some old parts soaked in a mixture of acetone and fuel to see if anything is adversely affected.
Nothing like 100 ml of benzene in 10 gallons of gas to beat spark knock.
hmm bit difficult to get hold of though. Not sure if my local drugs store would stock it.
Overdose the acetone, and you may indeed see problems.
Use normal dilutions, and you won't.
Try a little [in your situation] in your car.
It may help - don't count on it, and don't expect miracles.
Good luck!
They could always try some "Golden Drops" (or make their own!).
