Originally posted by TooSlick:
Dr T,
The ACEA A1/B1 oils are the lowest quality level available in Europe - they roughly correspond to the API, "SJ/CF" specification. The ACEA, A5/B5 oils are low viscosity versions of the ACEA, A3/B4 catagory and have the same test limits for wear/deposits/oil consumption, etc ....
Engines designed to use the ACEA A5/B5 oils normally have a roller type valvetrain design, to reduce the loads between the cam lobes and valve lifters. The thicker ACEA A3/B4 oils are better for direct acting cams, where the lobes push directly down on the tops of the lifter body.
Ted
