AC Shrader valve removal tool
I too have a Sable. I made the tool to remove the a/c schraeder valve out of scrap 1/4" brake tube and notched it with a saw.
Originally Posted By: meadows
I paid lesss than that at a local air conditioning parts shop
Yeah, not called around yet. Ill check it out.
They are clever tools, worth understanding even if you don't do A/C work. They let you change the valve core of a system under pressure, losing only a trivial amount of gas.
They are *not* the same as a simple valve core wrench, which can cost under $1.
Wow those are cool, I didn't know such a tool existed. I've never actually had to change a valve out but if I do I'll have to remember that.
that's awesome!
Isn't the Schrader valve just the secondary seal, the primary one being the screw on cap? As long as you have a good cap that does not leak, you do not even have to change out the valve core.
The Schrader valve is the primary seal. The cap might be a secondary seal --- some are just dust caps.
