Originally Posted By: qship1996
Originally Posted By: johnd
The guy that replaced my compressor told me that proper maintenance would be to, every four years or so, pump down the system, replace the dryer bag and recharge with fresh oil. He also admitted that almost no one, including himself does it.
That would be correct advise if you plan on keeping the car for the long haul {over 8-12 years or more} periodic dryer replacment keeps the moisture out of the system, which when combined with the oil becomes acidic and eats away at the condensor, evaporator,compressor seals, all O rings, and lines.While the system is evacuated, the oil removed is examined for color and debris and replaced with fresh oil. following this procedure every 4 years or so will extend the life of every component in the system,insure exact weight of refrigerent is in system,and cost about $150 to perform.
My 1993 camry with 229,000 miles has never had anything done to the closed system and still puts out perfectly cold air. I couldn't imagine taking apart the lines and drier as preventative maintenance.
And, I'm pretty particular with caring for my car, with plenty of fluid changes, etc.
But leave the AC system alone - other than the belts and keeping the condensor clean.
