I can tell you guys this. Advance Auto Parts, Parts America, Checker Shucks and Kragen, and I think Pep Boys all have the good AC filters. I even cut a good and bad AC filter apart and it does appear now that the ones at Autozone and Walmart are Champion; they truely suck in comparison to the real Delcos, which are made like a brick @#!*house
The good Delcos have probably twice as many outlet holes leading to the center outlet hole, and the 52 I cut open did have metal top end caps. If you want good Delco filters, look for the ones that have spot welds around the base plate, and also the good ones do not have crimps holding the gasket in place. Also, the crappy ones have a neon green serial number on the top of the case. I can't believe that we have to search things out like this in order to get a quality product
[ January 31, 2003, 10:02 AM: Message edited by: Drew99GT ]
