AC Delco PF454 to motorcraft oil filter part #
LONESTAR state
Sorry I have to make 2 topic, look like no one answer this question on my other thread, I really need this motorcraft part number ASAP.
I can't tell you since the MotorCraft site
http://www.fordparts.com/Products/Filters.aspx (hit "Next")
doesn't have the interchange utility working yet.
According to the Fram site, there is no MotorCraft x'ref. If you put your PF454 into their interchange utility
http://www.framcatalog.com/Competitor.aspx?b=F&pn=PF454&em=True
you get a PH8873. If you click on the number, it will open another page listing all of the competitor x'references. MotorCraft is not there.
While it may exist, I have yet to see a 13/16-16 thread MC filter
Edit: The Ford/MC interchange utility is working (now) and doe not recognize that filter number. It does not recognize the Fram number either ..nor the WIX 57099/51061/or any other 13/16-16 thread filter number that I can pull out of my behind.
a couple choices. I need to know the vehicle for exact cross reference.
wix Part Number: 57099
UPC Number: 765809570993
Principal Application: Chev/GMC Trks + Vans w/ 7.4L, 8.1L (99-07)
All Applications
Style: Spin-On Lube Filter
Service: Lube
Type: Full Flow
Media: Paper
Height: 3.306
Outer Diameter Top: 3.660
Outer Diameter Bottom: Closed
Thread Size: 13/16-16
By-Pass Valve Setting-PSI: None
Anti-Drain Back Valve: Yes
Burst Pressure-PSI: 245
Max Flow Rate: 9-11 GPM
Nominal Micron Rating: 21
Gasket Diameters
Number O.D. I.D. Thk.
Attached 3.444 3.100 0.260
this lower one converts to a FL12a . this is a larger filter.
wix Part Number: 51060
PRONTO Part # PO5313
SLE
$1.81
Add to Cart
AUTO EXTRA Part # 61851060 More Information About this Part
$1.99
Add to Cart
ACDELCO Part # PF454 More Information About this Part {#25324052} 81MM LONG
FILTER,OIL 2ND DESIGN; 76MM LG, FOR FIRST DESIGN SEE 25160561; WITH ANTI-DRAIN BACK VALVE
Part Image
Choose:
Add to Cart See Options at Left
WIX Part # 51060 More Information About this Part {#DG5, HM5, PH13, PH5, TG13, TG5, XG5}
Part Image
$4.29
Add to Cart
ACDELCO Part # PF1218 More Information About this Part {#25160561} DURAGUARD 115MM LONG
FILTER,OIL 1ST DESIGN; 138MM LG, FOR SECOND DESIGN SEE 25324052; WITH ANTI-DRAIN BACK VALVE
Part Image
$4.36
Add to Cart
MOTORCRAFT Part # FL12A More Information About this Part
Extended Passenger Van; RWD
Standard Cargo Van; RWD
Cutaway Van; RWD
Extended Cargo Van; RWD
Standard Passenger Van; RWD
$4.37
Add to Cart
MANN Part # ML1026 More Information About this Part (Only 12 Remaining)
Part Image
$4.53
Add to Cart
ACDELCO Part # PF1218CL More Information About this Part {#89060468} CLASSIC DESIGN 130MM LONG
FILTER,OIL 138MM LG, FOR SECOND DESIGN SEE 89060467
Part Image
$4.76
Add to Cart
BOSCH Part # 3322 More Information About this Part Premium
$4.83
Add to Cart
FRAM Part # PH8873 More Information About this Part Full-Flow Spin-on; Extra Guard; Includes Gasket (Rebate/Promotion Available! See Promotions & Rebates Page for Details.) Sale Item
Part Image
$7.42
Add to Cart
BOSCH Part # D3322 More Information About this Part Distance Plus (Only 4 Remaining)
$10.84
Add to Cart
ACDELCO Part # PF35L More Information About this Part {#25013454, 25322841, UPF1218} HIGH EFFICIENCY WITHOUT ANTI-DRAIN BACK VALVE
FILTER,OIL
Part Image
$11.04
Add to Cart
ACDELCO Part # PF454CL More Information About this Part {#89060467} CLASSIC DESIGN 81MM LONG
FILTER,OIL 76MM LG, FOR FIRST DESIGN SEE 89060468
Part Image
* Non-stock item--shipping delayed up to 5 business days
+ Sold in packs of 12; Price reflects cost of each individual item, not the pack
UPC Number: 765809510609
Principal Application: Chevrolet/GMC Trucks (91-05), Hummer (93-06)
All Applications
Service: Lube
Type: Full Flow
Media: Paper
Height: 5.178
Beta Ratio: 2/20=17/41
Burst Pressure-PSI: 270
Gasket Diameters
YOU ROCK !! so MOTORCRAFT Part # FL12A is the larger size and that what it work on my 97 camaro z28 5.7L right ?
how about 51060 wix or napa gold 1060 ( these is larger side filter for this car, im using 51060 or 1060 napa for for quiet some time now, and recently using mobil 1 M1-302 ). I really need this motorcraft filter that cross over any of those part I list above.
Originally Posted By: CamaroT56
any motorcraft filter that work on 97 camaro lt1 5.7L ?
fl-10
1997 CHEVROLET CAMARO Z28 5.7L 350cid V8 MFI (P) OHV : Engine : Oil Filter Wiki Price
PRO-TEC Part # 102 ProTec Spin-On Lube Filter (Only 13 Remaining)
$1.79
Add to Cart
PRONTO Part # PO5288
Z28 30th Anniversary Edition
Z28 SS 30th Anniversary Edition
$1.81
Add to Cart
AUTO EXTRA Part # 61851069 More Information About this Part
$1.85
Add to Cart
PRONTO Part # PO49
$2.02
Add to Cart
FILTER,OIL WITH ANTI-DRAIN BACK VALVE
Part Image
Choose:
PUROLATOR Part # L20049
Oil Filter LIMITED TO EXISTING INVENTORY [Wholesaler Closeout -- 30 Day Warranty] (Only 3 Remaining)
$2.52
Add to Cart
MANN Part # ML1016 More Information About this Part (Only 12 Remaining)
Part Image
$2.78
Add to Cart
FRAM Part # PH30 More Information About this Part Full-Flow Spin-on; Extra Guard; Includes Gasket (Rebate/Promotion Available! See Promotions & Rebates Page for Details.) Sale Item
Part Image
$4.12
Add to Cart
WIX Part # 51069 More Information About this Part {#DG30, HM30, PH30, TG30, XG30}
Part Image
$4.25
Add to Cart
MOTORCRAFT Part # FL10
FI; Height: 4.341; Inside: 3.812; Outside: 13/16-16THD.
$4.33
Add to Cart
BOSCH Part # 3420 More Information About this Part (Only 2 Remaining)
$4.52
Add to Cart
$4.83
Add to Cart
FRAM Part # TG30 More Information About this Part Tough Guard® Full-Flow Spin-on (Rebate/Promotion Available! See Promotions & Rebates Page for Details.) Sale Item
Part Image
$6.23
Add to Cart
FRAM Part # DG30 More Information About this Part Double Guard® Full-Flow Spin-on [Wholesaler Closeout -- 30 Day Warranty]
$6.35
Add to Cart
FRAM Part # XG30 More Information About this Part X2™ Full-Flow Spin-on (Rebate/Promotion Available! See Promotions & Rebates Page for Details.) Sale Item
Part Image
$7.34
Add to Cart
$10.84
Add to Cart
FILTER,OIL
Part Image
$5.30
Add to Cart
FRAM Part # HM30 More Information About this Part Full-Flow Spin-on; High Mileage
I am not sure the fl12 will fit just because of length but it looks like the threads and diam are the same . 4.3 height vs 5.2 so almost an inch taller for the fl12.
this the specs for a fl-10
Part Number: wix 51069
UPC Number: 765809510692
Principal Application: GM Family of Cars/Trucks (64-97)
All Applications
Service: Lube
Type: Full Flow
Media: Paper
Height: 4.338
Beta Ratio: 2/20=2/26
Burst Pressure-PSI: 225
Gasket Diameters
You have got to tell me why? I assure you this will not be a commonly stocked MC number ..just about anywhere. What makes you "have" to have this filter in MC?
What about them? The FoMoCo/MotorCraft interchange utility doesn't recognize any 13/16-16 thread filter number. When you put in FL12a you get the FL12a and you can see that it's a 13/16-16 filter, but it recognizes not one other man's filter number.
What I'm asking is what gives the MC filter such distinction in your view? I mean, it's a great filter @ $3.65 at Wally's ..but when you get too far out of that price range, you kinda have options up or down that might appear better.
I just went back to Fram and put FL12a into their parts interchange.
PH13/PH5 both xref to FL12/FL12A/FL12FP
I second Gary's question. What's wrong with the OEM ACDelco filter?
The only time I'd expect a MotorCraft (Ford) filter to fit a GM product is if that filter size also goes on some Ford product. Frankly, I wouldn't be expecting Ford to make filters in sizes that fit GM, or any other non-Ford brands, unless of course, those sizes overlap with one of Ford's brands' products.
Originally Posted By: satterfield
Does anybody have any info. about this oil? Thanks-- Dennis
Wow I thought this thread was about this oil and it appears to instead be about Motorcraft oil filters. LOL
