So I'm looking for a large-ish 3/4-16 threaded filter that fits my van and truck--and both vehicles need a filter with a bypass valve.
The Purolator L14670 is a good size for both, and has an appropriate bypass. I see that filter is used on a lot of modern Chrysler and Dodge applications....and I assume those cars use filters with bypass valves in them? When I cross reference this filter to Bosch, Fram and Wix equivanents, those filters also have bypasses.
Problem is, I ordered a couple AC Delco PF13CL (you know, the non-ecore "Classic" ones) And there appears to be no bypass valves in them. Anybody know if I can use these? Do they have bypass? The Delco site cross reference shows they work for the same Chrysler and Dodge engines, by the way.
