AC Delco dexos1
Originally Posted By: Jehartley
The ONLY GM engine requiring full synthetic are the Cadillac, Camaro, and Corvette.
I summarized above what the 2011 Corvette owners manual (available online here) stated about oil (page 10-20). Nowhere does it state or even imply that a synthetic oil is needed. On the contrary, it even allows for the use of any API 5W30 Starburst if dexos isn't available.
Thanks for posting the Corvette handbook; it's neat.
Yes GM says you can run any API 5w30 oil BUT it does recommend M1 for the Corvette.
So basically there would be no motor oil related warranty issue with GM as long as you run an API 5w30 grade and that includes mineral oil.
Okay, it doesn't "require" synthetic, but the manual does "recommend" synthetic, and it [censored] well comes from the factory with synthetic in it.
As the manual you posted states,"It is recommended to use Mobil 1® engine oils that meet the requirements of the dexos specification."...and Mobil 1 is a synthetic. So, you are wrong. It does indeed imply it by recommending it.
I'm not on board with this Dexos thing. I mean, GM6094M used to assure you were getting a decent conventional oil and really, to me, didn't mean much. HOWEVER - when an oil met GM4718M I really knew it was a good spec oil since only syn lubes could meet the demanding spec. Now, I see a semi-syn oil labeled Dexos that claims to be suitable for the GM4718M. I call [censored]. I have even read internal GM papers about Dexos and I am still not convinced this is the way GM should be going.
So, a recommendation implies a requirement?
Alrighty then...
Whatever. Sorry I wasted your time.
Alrighty then...
No, that's not what I said. Read the context of the posts, I was saying that a recommendation for synthetic implies that they want you to use a synthetic.
Personally I prefer that a manufacturer to "recommend" rather than "require" any particular motor oil.
The benefit of a 4718M oil only really applied in high oil temp' situations that you would encounter possibly on the track. For street use only it was not necessary.
Originally Posted By: aldead
Here is some more info from gf-5.com
gf-5 vs dexos 1 graphically
Thanks. That is exactly what I wanted to see. But I am confused as the graph indicates (using highlighted blue) the 4 categories for which the dexos1 Performance improvements above GF5. But looking only at the graph it shows several more (3?) for which the dexos1 is superior over GF-5.
