ABS codes
Minnesota
The abs light came on today in my 2005 Honda Accord. I decided to go to oriellys to have them scan the code but it turned off on the way there. Does anyone know if abs codes are stored in the computer after the light goes out? (I went to oriellys anyways but they didn't have an abs reader...)
On a side note the light came on after driving in heavy rain and then turned off once the roads were dry. I'm guessing it's a sensor?
The wheel sensors and wiring are the most susceptible to damage. Do a visual inspection-- I had a wire snag on a ball joint stud and pull out of the wheel bearing assy.
