I have been doing some research on here and the internet and have come to see that I should more than likely do an ATF change at 30,000 miles.
I seen on the http://www.handa-accessories.com/ They have the ATF and recommend changing it often too.
I have the Official Honda Service Manual and seen how to do the change. At the end it says to reset the Maintenance Minder System after the change. It says that if the System doesn't say to change to hook up HDS and reset it that way. I have no access to that since I will be doing the change myself, so does it really matter about resetting that?
Also how many of you are changing it at 30,000 miles? Or another set of miles?
I really want to take care of this CR-V, and I am learning as much as I can so I can do a lot of the work myself. So any extra help with this would be great thanks!
Also, the drain plug washers for the Transmission the same as the ones I bought to do the oil changes?
Adding another question lol : Is there a transmission filter to change too? If so How often should that be changed? The Transmission chapter in the manual is HUGE!! I'm trying to find it, but no luck just yet.
