Originally Posted By: aznboi24
Thanks for the compliments on the condition of the engine guys!
Yes, it is slightly modded, i'll be adding a homemade catch can soon cause the intake mani seems to pool with oil.
Hopefully the PVC valve will help with the venting. Im just concerned about the color difference. The intake mani and EGR ports did have quite a bit of carbon build up at 100k so I cleaned that out followed by 2 seafoam treatments so that might have clogged up the PVC valve. No carbon deposits on the old plugs though
Honestly, it's because of the headers. The stocks have heat shields (IIRC) and your Comptechs are just open stainless steel. They radiate LOTS of heat, especially at idle or just after shutdown. They are cooking your rear bank because they are tucked away with little/no airflow, which is why you see more varnish in the back. My RSX-S engine bay temps were noticeably higher when I put on my stainless DC race header. If you are really worried about the varnish, think about wrapping your header. Since it's stainless it won't rust. The ceramic coated ones are a different story.
