Originally Posted By: userfriendly
Ducked;
I don't know enough about manual transmissions to make an informed response to target your specific needs. However, contrary to popular opinion, modern GL-5s are yellow metal friendly, therefore can be used where brass/bronze/copper bushings are present. BP, Castrol here, might publish the copper strip pass results, 1-A being the best.
ASTM ... ?
Friction enhanced, in the case of TO-4s would be the opposite of a friction modified engine oil, and more like an automatic transmission fluid except in engine oil grades instead of ISO grades.
John Deere, Cat and others are very specific about wet clutch lock-up and fluid friction properties, anti-chatter braking and clutch pack life.
I like the idea of extra traction to help spin flat tappet lifters, and not so gaga about over the top ZDDP numbers as some other members might be.
Can't offhand see how that last bit (my bolding) would work with my flat tappets. Don't they inevitably follow the cam profile, at least on the up stroke? I suppose enhanced friction (adhesion?) could maybe make them follow it on the downstroke too, maybe reducing valve bounce, if that was an issue.
I can see how it might be relevant to roller cam followers because they, like, roll.
IIRC the bucket cam followers on pushrod engines are/were supposed to rotate around the pushrod axis (Its been a long time since I've had one in a car, though I did have a pushrod motorcycle until fairly recently) so maybe it works there too.
