A Good DashCam
Upper Midwest by the Lakes USA
SO here is all I hear about dashcams
1. It overheats
2. It drains car battery
3. I has disk errors
Does anybody have one that works?
I'd be satisfied even plugging it in manually to the cig lighter every-single-time I get into the car..... just as long as it works.
I'm interested as well, but the issue is my car is parked in the sun in 115 degree Phoenix heat. I doubt many would last in that.
I have one called: Panorama 2.
It had good reviews and was advertised as working in 'low' temps.
Problem with Dash Cams is,
It's not like buying a regular Camera.
Kodak and all the other Camera Companies do not make Dash Cams.
When I bought mine, they ALL came from:
* China
* Tiawain
* South Korea
A lot of talk about 'counterfeits'
I bought mine on E-Bay.
If you do, pick a 'Top Rated Seller"
I like mine a lot.
Bought Dec 2013 ...... $189.00
Mine plugs into Auxilary Outlet and has a 'Red' Button to turn Camera ON/OFF
I just bought a Mini 0805 dashcam. I popped open the cig lighter adapter and soldered some wires straight to the circuit board inside, so I would have two leads coming out. Then I wired it to an ignition switch source.
That prevents the battery drain problem. Some cars have a ignition-switched power port.
I haven't palyed with it too much, but, it works!
It will be hard to beat the performance and price of a G1WC from an authorized seller with a quality card. The market is flooded with fakes.
Just to be clear.. is it the W"c" or the W"h" previously linked to at the top posts?
^^^ I have the G1WC, it has a capacitor so no need to worry about battery overheating in the summer. G1WH has a 20 degree wider field of view, not sure of the other differences. What ever you decide, make sure it is from a legit seller and has a capacitor.
Originally Posted By: BobsArmory
I have always wanted a dash cam. They could really help you out in certain situations.
Absolutely. My wife in a recent wreck had two others lie to the police and blame her. Had we had a dashcam it would have been an open/shut case with egg on their faces. Never again.
* China
* Taiwan
* South Korea
I like mine a lot.
Of these 3 countries I think South Korea is the best(Samsung, LG are South Korean companies), next it Taiwan and China is last in term of quality.
The quality of G1W and A118/B40 series is not very good, and the chipset and sensor are outdated.
Now there are many dash cams with much better video and build quality. I have used Matego MG600 series with capacitor and remote lens,so the main unit can be hidden away from heat, and it's also more discreet.
http://www.amazon.com/dp/B017C3JMR4
