absolutely. Im currently in my heating/ac class in the automotive technology program im taking, and can verify everything said here is true.
You should go by the higher reading your getting, and you should most definitely have a gauge on your high side at the same time. The low side reading you have is a good reading, and your system is most likely ok since your a/c is blowing cold. But when diagnosing an A/C problem, that low side reading is completely useless without the high side reading to go along with it.
(if your orifice tube was clogged, you could have a lower then normal low side reading, and a high side reading so high its about to blow, and you'd never know it. you'd just keep pumping refrigerant in it til that low side reading was ok)
and theres no way you can accurately test an A/C if its only 61 degrees Fahrenheit outside..
