Hi all, the boss and I have been working on a 1995 Mercury Tracer off and on for a while now. The customer complaint was that in cold weather the windshield would fog over and he didn't think the compressor was running.
When it was just my boss doing the work, he replaced many things without checking, instead going for the "low hanging fruit" - the common things. He also consulted tech boards like IATN and Identifix.
Things he did/replaced:
Checked fuses
Checked A/C pressure in shop
Replaced low pressure switch
Replaced high pressure switch
Replaced cooling fan relay/switch
Replaced A/C relay
Replaced WOT cutout relay
He also realized that the problem is temp related. Works fine in warm temps (35*-40*+) but not cold temps.
It was at this point that I wanted a crack at it. With schematic in hand, I started checking it out. I determined that the negative signal from the control head to the low pressure switch wasn't passing through the switch. Why? A/C system pressure was too low. Boss checked outside and it was near zero. Added almost 2 cans of freon. Problem still existed. Adjusted the low pressure switch (cycling switch) so it would come on at lower pressures... Then it wouldn't cycle.
And that's where we're pretty much at. Either the A/C and defrost works at normal temps and cycles, and doesn't work at low temps, or you adjust the low pressure switch, then it engages at low temps but won't cycle.
After my wire chasing and finding that the low pressure switch was not closing due to low pressure, he replaced the receiver, high pressure line and expansion valve. Problem still persists..
Now admittedly I know very little of A/C theory and how it operates, but I can follow a schematic and chase wires fine. It appears that wiring and related components are correctly functioning - either because they were tested, or randomly replaced. Everything that I see points to the A/C system pressure being too low to close the contacts on the low pressure switch, thus the PCM doesn't see the input it needs to tell the WOT relay to kick in the A/C clutch. Boss says that pressure are correct, and at room temp, I'm inclined to believe him. But every time the compressor won't kick in I can pull the wiring connector off the low pressure switch and the contacts will be open. That to me says that the pressure is too low when cold.
I know that I'm probably jumping around a bit and I'm sure there is some info left out - probably because I've been over it so many times and am taking certain things for granted. Feel free to pick my brain. If need be, I can scratch out the schematic... It's been permanently burned into my brain!
Checked fuses
Replaced A/C relay
