Today, I had the A/C system on my dad's 92 Toyota minivan converted from R12 to R134A. I'm not sure if it was done correctly, but here's what my mechanic did.
- Replaced the receiver drier and the o-rings at the receiver drier.
- Flushed the system with A/C solvent and blew it dry with shop air.
- Installed new R134A fittings.
- Did a 15 min vacuum
- Added 4 ounces of Ester oil through the machine's injector. (Toyota recommended amount is 6 ounces)
- Charged with 2.5 lbs of R-134A (Toyota recommended amount for this vehicle when converting to R134A)
The system blows relatively cold, but not as cold as R-12. My mechanic was hesitant to use the full 6 ounces of oil as recommended; he claimed that it might cause the compressor to knock or severely reduce system performance.
The reason why the system was converted to R134A in the first place is because I have a leak somewhere that caused all of the oil to leak out of the rear evaporator. I had the rear evaporator replaced and the system recharged with R12, but it still leaked. That's why I had today's conversion performed. However, after performing the conversion today, we were unable to find any leaks.
So what should I do? Should I go back and have him add more oil into the system? Any idea on the leak?
Thanks!
Thanks!
