This is more of a tale of buying an older home and dealing with all the trials and tribulations with it.
January 2022 I bought my current house. It had been vacant around July or August 2021 when the previous and original owner was diagnosed with brain cancer months prior and no longer care for themselves. It had an old Water Right water softener dated March 2000. Brine tank was pretty nasty looking and I was just going to replace it right off the bat, but everyone knows how expensive buying a house is. So, I drained all the water out of it, cleaned the tank, refilled the salt tank with fresh pellets, manually did a regen and low and behold it still worked! Hey, score!
October/November 2023 we were still in a particularly dry period and I went and checked on the softener. Low and behold the brine tank was overflowed and nasty looking.
I figured since I have no pre-filter the well may have sucked up some dirt. But, I looked closer at the drain line stung across the basement. Tubing was too thin and squeezed off in several spots. Not to mention there was no trap, and the plumbing was slightly pitched backwards so brine water was backing up into the sump pump by way of slightly seeping backflow valve. This also meant the sump pump was connected to the septic system. That's a big no-no. Everything cut out and re-worked.
Old:
New:
This is what the salt water did to a formerly nice Zoeller pump
Drained and cleaned the brine tank yet again, filled with fresh salt, and we were back in business!
March 2025 one Saturday evening I went down to grab an adult soda out of the fridge and caught a glimpse of water all over the floor in the pressure tank and water softener area. Fearing the worst the tank went out, I found the brine tank filled itself up and was overflowing out the overflow tube. OK, maybe the plastic drain tubing messed up again as there was a kink in it. Drained a bunch of water out of it, and cleaned the water on the floor the best I could. Went on the ol' Amazon and ordered some thicker tubing. You can kinda see the bottom plate on the wall still wet.
This did unfortunately go all under the wall and the vinyl plank flooring. Set the whole basement dehumidifier to Arizona desert and moved the rug to dry out.
Next morning I woke up and looked in the brine tank. Almost full again. Gah!
Welp, she's done. Put in bypass mode. Was thinking maybe the water isn't that bad. Couple weeks go by and it's apparent I have some pretty hard water. Weekly tub/shower cleanings with an acid base cleaner. OK, this is my life for a while now.
So I've been noticing the dishwasher which previously would always be spotless inside is now nasty as it can be. Decided yesterday I need to clean it. I had some ZEP calcium, rust, iron remover. Liberally applied (my first mistake) all over the bottom and the staining instantly started melting away. Took a microfiber and scubbed the sides down. Closed the door and set the timer for a rinse only cycle. Not even a minute later I notice the sound of splashing water quickly stopping. Oh, did I mess up. Right then and there a drop of foam came out of the dishwasher and I quickly put a stop to the cycle. Opened up and it was foam city! Had to keep rinsing with cold water and setting the timer to drain. Crisis adverted, but took a while.
Decided enough was enough and opened up the wallet and ordered this unit with a 3/4" head:
https://aquasureusa.com/products/aq...le-house-water-softening-system-32-000-grains
Will be installing a pre-filter this time around. We'll see how much a dumpster fire this all will be.
Hope some of you got a kick out of my little misfortune. Don't be like me and cheap out. I could have lost flooring in the basement and even kitchen had I not been cleaning up after dinner prep.
Old:
New:
