HI,
Thanks in advance for both the Place to ask for help and any help offered .
The Three Year Mystery !
Returning Home from a 200 mile trip (Normal oil change done just before by Me) 50 Miles or so into return trip Bright RED warning light ....CHECK GAGES!!. Good thing nobody was around as i did swerve slightly as I scanned around Finally to notice OIL Needle pointing at 0 . WHAT!! I instantly Threw it in netural and turned off the ignition. Coasted safely to the side.. Being thats its 2 a.m. and dont have my cell phone. . So I sat for a few thinking I must have Dropped a drain plug cause I Just checked the Oil level less than 50 miles back when I got gas. and it was half a quart low. so i put some in.
I exit & walk to the back and think sweet no trail. Open the hood, check the oil good ?....OH! Wait... if I have Oil and no pressure that means the Pump gave? Now what . I could sleep in the van for the night then walk to call my son and a tow truck . I decide to try starting it JUST in case it is pumping and it s the instrument cluster?? Start it and i have normal readings Ok lets drive . get about 15 miles BOOM there it is again the needle at 0 . Just slowed this time and sliped it into netural and pressure returned. OK time to Test if this is JUST a sensor or there really is no OIL pressure. as this is 2 A.M. I sat and let it idle for a few with the gage reading 0. 1 min .....minute 30....ohhh I hear ticking .... yep there it is noooooo. turn it off.
....turns out IF I let it sit for 10 mins I can drive for 10 -12 mins. so this is how i got my butt home. Lucky for me as I Bought this used off the lot and have an extended warranty!
Start it up in the morning drive to Dealer. Explain my fun the Night before to the write up guy even telling him i let it run for about a min and heard a faint tick and turned it off. after waiting I always have good pressure. Specifically said "so i doubt it's just a sensor". Leave and they call the next day "Your vans ready" Oh what was it . "the oil sending unit"
paid my $100 Ded. as i turn out the Drive the needle went to .....you Guessed it "0". Turned right back into the next Driveway pulled around to the write up desk. HEY ITS STILL DOING IT!!!....take him out side and its reading 40 PSI.
Well we cant fix it if its working. and he goes back inside & I let it idle till the Bright Red light appeared and went to get him ..Now do you see that its still doing it? I leave the van with them again.
3 days later I pick the van up after they put in a NEW oil Pump. What do you mean I have to pay you again you didn't fix it the first time ? back and forth..OK what ever. I pay another Deductible.
Drives Fantastic.....till a year later . are you kidding me I just changed the oil. I always change the oil. OCD even about the [censored] oil. Take it back... bummer are you kidding the oil pump went and NOW its out of warrenty?? you just put that in . the original was good for 8 years and about 95,000 miles and yours was good for a year and only 12,000 well they did end up replacing it again.
8 months later it did it again this time I Did a motor Flush and it went away ...that was 4 months ago. Last month when it happened I took it to an "oil Place" and had them do a flush. Cause its cold out side and my Camaro OWNES my one car garage...lol.
Last week it did it again. MY intervall is Shrinking fast this is my only way to work . MY drive to work is 20 mins long and all E-way.
The important Stuff.
99 Doge Ram 150
5.2 L
Usual brand of choice was Quaker State but last few changes were castrol. and filter was usually what was on sale...Dont beat me up to much . Teach me i will change....lol
Idle PSI 30 or so. @ speed 50-60 ish..
Full conversion HI-Top
Runs and Drives Fantastic!
Drinks about a Quart a month. No Leaks . and I don't see smoke when driving.
Just did Seafoam 1/2 can in crank case. (Can I leave this in?)
Yes have always kept up on the oil changes and filter on each one have no clue as to before I got it with 80,000 = miles on it . No I haven't even had a look into the valve cover as its under the dog house . and the filler tube is about a mile long. AS i believed till recently it was the pump but now I don't think it ever was the pump.
Any help is really gonna be appreciated.
AT one point the porter brought me the car ticking loudly with out pressure HERE its Fixed!!!! So yes there is more to this but this is the main points the Ticking that was present from the last fiasico with the dealer just went away after the last flush. sounds really good on start up now. but the little puff of blue smoke is still there.
99 Doge Ram 150
5.2 L
