99 Lexus GS400
104,598 vehicle miles
88,717 on T-IV ATF
single 2qt drain/fill done at 66,700 miles (8.4qt total capacity).
I'm planning the following service regimen: (in order)
1) 4x 2qt drain/fills with supertech ATF
2) pan drop & clean magnets
3) 9qt cooler line exchange w/ Amsoil ATF
Blackstone Comments:
We have seen nearly 40 samples from this type of transmission, and their average wear is listed in the universal averages column. On average, the oil in this type of transmission has been run about 13,000 miles. We'd guess this oil was run a lot longer than that. The only source we know of for lead is marking compound used at the factory -- is this factory original oil? We doubt it, but it's entirely possible this oil has only been changed once. Insolubles were high -- a sign the oil was run long. This oil should be changed & the system flushed.
Code:
OCI 88,717 _____ Universal
Veh Mi 104,598 Averages
Type Toyota T-IV ATF
Date 3/22/2007
Al 143 16
Cr 0 0
Fe 53 34
Cu 50 72
Pb 120 14
Sn 1 2
Mo 0 1
Ni 0 0
Mn 1 1
Ag 0 0
Ti 0 0
K 0 7
B 43 54
Si 54 20
Na 2 3
Ca 127 128
Mg 2 28
P 274 278
Zn 17 84
Ba 4 3
Visc 44.8 43-51
Flsh Pt 385 >335
Fuel 0 0
Coolant 0 0
H2O 0 0
Insol 0.2
oil blotter from this ATF...
88,717 on T-IV ATF
Code:
Date 3/22/2007
Al 143 16
Cr 0 0
Fe 53 34
Cu 50 72
Pb 120 14
Sn 1 2
Mo 0 1
Ni 0 0
Mn 1 1
Ag 0 0
Ti 0 0
K 0 7
B 43 54
Si 54 20
Na 2 3
Ca 127 128
Mg 2 28
P 274 278
Zn 17 84
Ba 4 3
Visc 44.8 43-51
Flsh Pt 385 >335
Fuel 0 0
Coolant 0 0
H2O 0 0
Insol 0.2
