I have a neighbor with a 1999 Dakota with (I think) the 5.2 V8 engine. The pickup seems to run great with the exception of one issue that started this summer.
If you're driving on a flat highway and holding it at a steady speed (such as 55 mph) every minute or so the engine seems to stumble a bit-there is a change in engine RPM's of about 100 RPM's-sort of a bounce up and down. It feels like a misfire, but it's so infrequent that I'm hesitant to call it a misfire. It only lasts a second, and then the engine is steady for another minute or so.
It doesn't happen if you're on hills or varying the speed with the throttle, only when the engine is held at a steady highway speed. It also doesn't happen all the time-sometimes he says that it doesn't happen for a day or two, then it will start again.
There is no check engine light and there are no stored codes. Earlier this year he did have a check engine light and the code was for the #7 fuel injector. He ran a couple bottles of fuel system cleaner through it and the check engine light/code never returned.
Any suggestions on what might cause the stumble on occasion?
Thanks!
Thanks!
