I know many cars today have a coolant temp sensor for the dash gauge and a separate temp sensor for the ECM/ computer. I am asking because my dau.s 1998 Jeep Wrangler with 2.5L 4 cylinder engine and manual trans. recently had a new water pump installed. After this procedure, the dash coolant temp. sensor read about 150* under all conditions. I got the shop to replace it, but now wunder if the defective sensor was also feeding bad info to the engine computer or is there a separate sensor for that? If it was used for both, it would be like having the carb. choke stuck on continuously in the old days. Results would be bad MPG.
