98 LeSabre, how many front balljoints are Thier?
stamford, CT
Simple question sorry all! Need new ball joints front suspension. How many do I need? 2 or 4? Ate Thier uppers to? I lnow thiers lower ball joints,but uppers?
If I need info about my '16 Camrys, I search the interwebs. Google and you tube are your friends A 98 GM should have tons of "how tos?"
My guess is two ( corrected by ZRX )
A few people call upper strut mounts upper ball joints. It's something of a misnomer, though they do articulate like ball joints do.
Jack the car up then put a pry bar under the tire and lift, if you get clunks from up top the strut mounts are shot. Lift the whole front end so the sway bar doesn't fight you.
Thanks! I thought perhaps Thier was an upper ball joint too, front .phew! Less money !:)
By the time the lower BJs on that vehicle go bad, normally the upper strut mount needs replaced too, and possibly the struts while you're at it, then the alignment.
I had a '97, inherited from my parents and one thing I recall about it was that it had greaseable BJs from the factory, but the place they took it to for oil changes (same dealership they bought it from, no less), never lubed it, assumed it had sealed BJs.
Meh, similarly I tend to call anything that needs a spring compressor a strut. This is because coming from a rock crawling background, "coilover" tends to mean high-zoot, supple, infinitely adjustable with potential for absurd wheel travel (and limit straps accordingly!)
