98 Honda Civic d16y7 causing confusion...
Indiana
I cannot locate a gasket for the water neck. This is where the upper radiator house meets the block. I'm going to install a new radiator and want to flush the block and refill with 50% dIstilled and antifreeze but want to make sure I have all leaks taken care of. Any advice
I had previously used O' Reillys brand water neck sealant, I've used it twice and still has a slow leak. I believe that leak exacerbated the leak in the radiator.
I'm starting a job there Tuesday so I'll be picking it up along with the radiator. Should I still apply RTV, and what formula is suggested?
If no gasket, use ultra gray or Right Stuff. If using a gasket- no silicone. Prep both surfaces- clean shiny metal, no left over anything.
Originally Posted By: Jiffy_Chris
Does it need a certain time to dry or cure after I reinstall before I can fill with coolant and drive?
RTV does require time to cure, but it varies by the type of RTV. Every RTV container will state what the curing time is.
I have heard HondaBond is an amazing RTV, but I never had the chance to use it.
