98 Expedition Heater Hose - Need Identification
Florida
I have a 98 Expedition 5.4 4x4 with rear heat.
I am looking for a part number for the hose that comes from the tube off the back of the water pump to the heater core and splits to the line that feeds the rear heat.
I would like the quick connect fittings, since one of the connections is in a really tight spot. Plus I want to replace the entire hose due to my transmission fluid in cooling system problem and since this one connects to the tube behind the intake, I want to replace it before reinstalling the intake.
Here is a picture of the hose minus the quick connect fitting that goes to the heater core.
[Linked Image]
I saw those hoses on Rock Auto.
I was having troubles identifying by their picture whether this hose in the picture I showed is the input or output hose.
RA only has the Motorcraft inlet hose.
Originally Posted by edwardh1
that sure is a complicated collection of connections, is it oem like that?
Yes, that is how Ford did it on the Expedition with rear heat. One hose comes from the water pump (or the intake depending on whether it is supply or return), the T spits that with one hose going to the front heater core and the other connecting to tubes that feed the rear heater core.
