98 Accord P1456 causes - Thx!
Los Gatos, CA
My friend's 1998 Accord, 155K, threw a P1456 trouble code. I replaced the gas cap with a Honda cap 1 year ago (about 12K) as it was throwing this code fairly regularly.
I told Cindy to make sure she tightens it using the 3 click method...
I will inspect the gas cap, but it seems unlikely it would be bad this soon. I believe this is a common Honda problem. I will look for any cracked hoses, etc.
Any advice on a likely cause? Thanks in advance.
my 99 accord has been doing that for years now, tried the gas cap, didn't work so apparently a leak somewhere. does not seem to affect anything with my car so I let the light shine on ...only way i can see this a problem is if you need an emission inspection..
