With the car running, if I remove the oil filler cap or remove the PCV, a forceful amount of air is blowing out of the valve cover. I've seen some YouTube videos where people are adding an Engine Flush to a running engine with no problem. If I tried this, no question, I'd be wearing whatever I was trying to add.
Looking thru another web site and someone posted a similar issue... they were told that this was Blow-By and not a problem - just a typical issue with a HM vehicle
This 1998 Accord has 187,700 miles. The timing chain was replaced at 175k. The PCV is changed routinely and, when running, a good amount of vacuum can be felt if you place your finger over the tip. I did a dry compression test a few months ago and the numbers were spot on - can't recall exactly now but I'm, thinking in the 190 range...?
A couple questions:
1. What exactly is blow by?
2. Is the amount of air coming out through the valve cover (oil fill and PCV) anything to worry about?
Any feedback would be appreciated
Thank you
A couple questions:
Thank you
