Hopefully I get some ideas. I'm having this sudden (as of yesterday) problem with my 97 Maxima (with a slushbox).
The symptoms are (only when engine is hot):
1. stalling when coming to a stop in drive, when the engine would go from almost no gas to having to keep idle - some (sudden) load on the engine. Once stalled, I can crank it to start again. Putting the tranny in neutral right before the stall saves the idles. No stalling in neutral or park so far.
2. sputtering (behaves like running out of gas) around 1500 rpm with more than a light load on the engine, like going up hills or accelerating from a stop.
The only thing I did different yesterday before the issue occurred was driving rather spirited, including up hills. It was also a hot (100F) day. My OBDII code reader can't find any codes.
