Vehicle----------1997 Honda Civic EX,
Engine-----------D16Y8 1.6L VTEC, 4 cyl
Trans------------Five Speed Manual
OIL--------------3.8 qt Amsoil SSO 0W-30 (First run)
Oil additive-----None
Make-up oil----2.5qts (approx)
Oil filter---------Honda OEM #15400-PLM-A02 (Manufacturer – Honeywell)
Air filter---------K&N OE Replacement Panel Filter # #33-2104
Miles on oil/filter------7,504 (approx 10 months – April to February)
Miles on vehicle—---137,458 (owned since 41,000-miles)
UOA by Oil Analyzers Inc:
WEAR METALS (PPM)
iron-------------------11
chromium-------------0
nickel------------------0
aluminum-------------6
copper----------------8
lead-------------------33
tin---------------------0
cadmium--------------0
silver------------------0
vanadium-------------0
Contaminant Metals (PPM)
silicon------------------6
sodium----------------27
potassium-------------1
Multi-Source Metals (PPM)
titanium-----------------0
molybdenum-------------1
antimony-----------------0
manganese--------------0
lithium-------------------0
boron---------------------6
Additive Metals (PPM)
magnesium----------42
calcium-------------3540
barium-----------------0
phosphorus--------802
zinc-----------------944
fuel-----------------3.0%
visc40---------------n/a
visc100--------------9.3 (rated at 10.3 but still in grade with SAE 30 range)
water---------------- soot/solids---------- coolant---------------NO
change---------------YES
oxida-----------------38
nitr------------------26
TBN------------------3.85 (started at 13.2)
Background notes:
Prior to the OCI shown here in this UOA, Castrol GTX 5W-30 was used almost entirely during the last 100,000-miles of operation and changed every 3,000-miles/3-months.
Driving habits included mostly in town driving of less than 10-mile trips and monthly trips of 100-miles or more. Seasonal ambient temperatures range from -5F to 115F.
At approximately 130,000-miles, the beginning of this OCI, the motor oil was changed to Amsoil Signature Series SAE 0W-30 (SSO). Amsoil Engine Flush was utilized before the switch to Amsoil synthetic motor oil. Engine flush recommendations were followed carefully. After the engine flush was complete and the old motor oil was drained out, it was observed that fine black carbon like particles were suspended in the old motor oil. A new Honda OEM oil filter was installed and new Amsoil motor oil added filling the sump capacity to 3.8qts.
Other noteworthy conditions of this OCI include spark plug replacement and valve adjustment going 5,700-miles past the recommended service interval. It’s assumed that the higher lead, shearing effect, low TBN and fuel dilution is related to the slightly neglected maintenance. These maintenance items were addressed at the end of this OCI. The Honda technician that performed the valve adjustment noted the presence of a hard baked on carbon like substance on the inside surface of the valve cover. It was said that two trips to the solvent tank was unable to remove the deposits. The recommendation was to change OCIs from 3,000-miles to 1,500-miles in order to prevent further deposit build-up.
Directly after the valve adjustment was completed, the motor oil was drained, oil sampled for this UOA, new Amsoil (SSO) and Amsoil EaO 20 oil filter installed. Other new equipment includes a AMSOIL Ea Universal Air Induction Filter in the place of the K&N. This next OCI will run for 12-months and is not expected to exceed 10,000-miles. Another UOA will be performed at that time.
WEAR METALS (PPM)
Background notes:
