Ok, so i would like to change the transmission filter on this beast, however it has 178K and a mostly unknown service history to me.
I have heard that changing the fluid on a transmission this old will generally result in slippage and problems, supposedly due to the worn friction surfaces and the friction material being in the old fluid allowing the transmission to function. As it was explained to me, the new fluid will not have the friction material and will cause the clutches to not function properly. (I have no idea, but can see the theory)
What I was wondering, is if I do a pan drop, filter change and use the same fluid or say-8 quarts come out, replace two of those quarts with new ATF and re-use the old? I know this is a band aid, but a rebuild is expensive and I would like to prolong the inevitable.
Has anyone ever done this? My idea on replacing the filter is simply to ensure that the fluid can flow as well as possible in the system and hopefully that will keep the transmission running for quite a while longer than if i did not change the filter.
