Err ..wait a second ....
51087
UPC Number: 765809510876
Principal Application: Ford European-Dorset Engs.
All Applications
Style: Spin-On Lube Filter
Service: Lube
Type: Full Flow
Media: Paper
Height: 5.477
Outer Diameter Top: 3.661
Outer Diameter Bottom: Closed
Thread Size: 22X1.5 MM
By-Pass Valve Setting-PSI: 19
Anti-Drain Back Valve: Yes
Gasket Diameters
Number O.D. I.D. Thk.
Attached 2.834 2.462 0.200
In a Donaldson
P550600
Lube Filters Product Attributes
A - OD (Inches): 3.15
B - Thread Size (Inches): M22 X 1.5
C - Length (Inches): 3.17
D (Inches): 2.94
E (Inches): 2.43
Primary Application: HONDA 15400PL2004, 005, 305
but the gasket is a little bigger on the Wix
51378
UPC Number: 765809513785
Principal Application: Acura (88-05), Sterling 827 (89-91)
All Applications
Service: Lube
Type: Full Flow
Media: Paper
Height: 3.170
Outer Diameter Top: 3.152
By-Pass Valve Setting-PSI: 9-12
Gasket Diameters
Attached 2.940 2.630 0.235
Part Number: 51592
UPC Number: 765809515925
Principal Application: Cummins, Komatsu, Onan Engines
All Applications
Service: Lube
Type: Full Flow
Media: Paper
Height: 5.214
Outer Diameter Top: 3.663
By-Pass Valve Setting-PSI: 18-20
Gasket Diameters
15614 2.834 2.462 0.255
donaldson
Hey, I'm waiting for an ebay auction to finish
