History on the car:
96 ex civic with probably close to 300k miles
consumes some oil and coolant
overheats due to bad cooling fans
friend came over saying his car had a weird bop bop bop bop noise and i found the problem. His spark plug wire popped out a little and cannot be inserted back all the way. Its still attached enough into the spark plug to get it a spark(i think).I tried to remove the spark plug, but i can't even get the socket in there. This is on cylinder 2, the other three are fine. We started the engine, i put my finger on the spark plug wire of cylinder 2 and feel a push/vibration and i'm thinking...bent rod or misfiring...
Car runs fine still..its weird
What i've tried/done:
blew out the spark plug hole with compressed air(maybe debris? nope wasn't)
can't insert spark plug wire 1 into spark plug 2. so that means spark plug 2 has something physically wrong with it. I also compared the spark plug wires and they are the same length and nothing fell off the spark plug wire.
this is as far as it can be pushed in:
video of the noise: BOP BOP BOP noise is what you're hearing. Click the video
anyone know the problem????
