Yep, you guessed it, the rear main seal on my 95 Lumina is leaking. Mechanic tells me its not bad enough to be worth fixing right now. So, basically, I'm getting quarter sized oil puddles on my garage floor, but it's not even leaking enough to worry about adding oil between OCI's. Not yet anyway. Now I'm pondering the Castrol HM or the Valvoline HM and stuck as to which one to use. Tallpaul provides a really good sales pitch for the Valvoline HM with its PAO and moly content, plus its advertised as synthetic blend. Castrol HM is not marketed has heavily as the Maxlife. I know I couldn't go wrong with either choice, but I’m leaning toward the Castrol.
I hope this rear main seal doesn't mean my car is in the twilight of it's life on earth, but correct me if I'm wrong….Do many car engines outlast minor leaks like this where the main seal never gets much worse than it already is?
