95 Buick 3800 engine
ontario,canada
Hello guy,s ,just picked up a 95 Buick Lesaber with a 3800 v6 engine for a winter beater.What I would like to know is if these engines were prone to sludge,I already ordered two bottles of AUTO-RX and was wondering if the I should do the 2 once deal,also can someone tell me where the heck the PCV valve is located on this engine can,t find it anywhere
THANKS
Welcome to oil testing and watching coolant levels for danger signs of antifreeze leaking through your plastic intake manifold. 3/4 of them fail and some more than once. Great car and motor other than that. I don't oil test my other cars but I oil test my GM V6s.
Absolutely not. The 3800 may be the most non-sludging engine made. Here is my 3800 with ~210k miles. Use the Auto-RX on the transmission. Your engine should be a non-series II engine. I don't believe they had any intake problems. Some of the series II do, but only IMO if they are run low on coolant or it is changed incorrectly.
-T
Hey T-Keith thanks for the info,would you recommed flushing the transmission on a car with 200,000 miles,I have heard this can cause more problems than cures.By the way the manifold on my car looks like aluminum ,the plenium is plastic THANKS
Yes 94+ models have a plastic upper intake, some 95 models and all 96's are series II. I can't recomend "flushing" because they usually don't change the transmission filter. I do recomend two changes in short succession if it hasn't been changed in a while. My car had 210k when I bought it and the fluid was black, after a few changes and auto-RX it still works great and the fluid is clean.
3800 is a good engine.
DON'T flush, you don't need a bunch of solvent being forced through the transmission at that mileage. "Gently" change fluid and filter a couple of times as mentioned above to ensure that fluid in the torque converter eventually gets changed out as well.
Hey thanks guy,s I will take your advice and drain and refill trans a couple of times and go from there.Really appreciate your advice..
