I'm the original owner.
The vehicle has ~125K miles.
Transaxle Fuid was changed at 80K ,and 103K.
Around 110K, I had a radiator bypass hose blow and the engine hit the red line before I noticed it and shut down.
Engine fine, but shortly after that, I started leaking a small amount (less than a quart a year) of ATF4, from the bell housing.
(My guess is front pump seal NOT the convertor).
I've noticed also hard shifting from Reverse to Drive at first Startup in the Morning and Sitting overnight, once in awhile.
If I wait 2 minutes, the hard shifing mitigates itself (sometimes not, or not as hard).
The last month or two the hard shift has gotten more frequent and worse.
Would a Change of Fluid *ATF4" or Lubguard Red help mitigate the: (1) leak, or (2) Hard Shifting?
Regards.
Regards.
