This is not my uoa.
It was posted on nasioc and is a very popular cocktail used by folks looking for the right combination of friction for the synchros and protection for the gears (hopefully). It is known in the Subaru community as "Uncle Scotty's Cocktail" and I know that there have been people here that have tried it.
I've never used it because I only use GL5 gear oils and have never mixed different brands. Given the mileage, I would guess that the high iron is due to the age of the car but it's hard to tell without a comparison. There will be a WRX uoa on it soon.
Do you see many uoa/voa's here with this amount of calcium, moly and magnesium?
Would appreciate some comments!! Anyone think that a thicker viscosity oil would be more appropriate for this car? Or maybe a GL5?
Unviversal averages in parentheses:
Equipment make: Subaru
Equipment model: Legacy
Oil use interval: 6,500
Make-up oil: 0
Oil type & Grade:
1.0 qt. Redline Shockproof Heavyweight
1.0 qt. Pennzoil Synchromesh
1.7 qt. Castrol Hypoy C 80W90
Miles on unit: 264,191
Aluminum 10 (13)
Chromium 1 (2)
Iron 90 (107)
Copper 7 (26)
Lead 0 (15)
Tin 0 (1)
Molybdenum 1228 (14)
Nickel 0 (1)
Maganese 2 (4)
Silver 0 (0)
Titanium 1 (0)
Potassium 1 (1)
Boron 147 (151)
Silicon 43 (38)
Sodium 24 (5)
Calcium 10900 (257)
Magnesium 1453 (4)
Phosphorous 1384 (1533)
Zinc 310 (413)
Barium 0 (11)
Properties
cStViscosity @ 100C: 13.78
Fuel: -
Antifreeze: -
Flashpoint: 395F
Water: 0
Insolubles: .8
Thanks for the note. This is an interesting mix of oil here, in Uncle Scotty’s Cocktail. Is it corrosive? Well, we didn’t find anything in this sample that would indicate it’s corrosive, though if you wanted to do a TAN test, that would tell you how acidic it is. Iron read high, when you consider that averages are based on 33,000 miles on the oil and this oil was run 6,500. We don’t know where the metals stood before this – whether they’re getting worse or better. Iron is the only thing reading out of line.
-Dennis
Make-up oil: 0
Oil type & Grade:
Aluminum 10 (13)
Chromium 1 (2)
Iron 90 (107)
Copper 7 (26)
Lead 0 (15)
Tin 0 (1)
Nickel 0 (1)
Maganese 2 (4)
Silver 0 (0)
Titanium 1 (0)
Potassium 1 (1)
Boron 147 (151)
Silicon 43 (38)
Sodium 24 (5)
Calcium 10900 (257)
Magnesium 1453 (4)
Zinc 310 (413)
Barium 0 (11)
Properties
Fuel: -
Antifreeze: -
Flashpoint: 395F
Water: 0
Insolubles: .8
-Dennis
