92 F250 7.3 oil?
Being in Canada, you should at least try a 5w-40 to help with startup. Rotella, Delo, Mobil 1 or Delvac, etc. 15w40 makes for some rough starts when it's -30F out.
5w40 T6 if you can get it. Any 0w40/5w40 diesel spced oil should work well.Check the condition of the GP system and make sure it's 100%. Make sure you have no fuel leaks as they will make a diesel hard to start. Check the block heater and replace the cord if needed. I'd plug her in at least 10 hours before you start it. You may want a timer for the block heater.
