OVERKILL
$100 Site Donor 2021
Originally Posted By: SteveSRT8
Does anyone have the low oil pressure specification for this engine?
As an example we don't worry much about oil pressure any more because it can be very low and still be acceptable. Plus the PCM in our trucks will pull the spark if it goes under 6 psi, thus usually preventing any damages at all.
My guess is that the OP's pressures are well within Ford specs.
All I have to go by is what I've seen in terms of bottom-end wear and what the engine had for oil pressure.
Engines with pressure in the mid to high 30's on a 30-weight were in excellent shape. A friend of mine had one with 15psi on 20w50 and it looked like the 4 horsemen had come and wreaked havoc on his bearings.
Keep in mind, the above is specific only to the 302 Ford and no other engine.
