I'm looking at an 89 Chevrolet 2wheel drive pickup with 305 engine. My 91 that I am replacing is a 4WD. Can the rear end be easily swapped out for a 2 wheel drive rear end with locking rear differential? What all is involved?
Yeah, only 5 lug on the 2wd half tons. Another potential stumbling block is the gear ratio. ie, the axle out of the 2wd would need to match the front diff of the 4wd it's going into.Isn't the 2wd 5 lug while 4x4 is 6 lug? At least the 1 /2 ton trucks?
With front wheels chocked securely, raise the rear of the pickup and remove the tires.Whole axle.
Yep, two floor jacks, jack stands, chocks, new U bolts, shackles/bolts, and maybe an angle grinder …I would imagine swapping axles on 30+ year old rustbelt trucks will be a nightmare.
Heat, impact, cutting wheel. Like butter.Yep, two floor jacks, jack stands, chocks, new U bolts, shackles/bolts, and maybe an angle grinder …
(or Victor wrench) …![]()
