got a freebie in that i got running.
but the oil pressure and battery voltage read high and coolant temp low.coolant temp not verified but i get good heat and fast.
battery voltage is 14.2v running.
oil pressure is 30 psi at hot idle verified with mech gauge.oil pressure on dash shows 50+psi
all body grounds are present and good.
i assume there is a regulated voltage source the instruments run from but no luck finding it.
haynes/clymer manual does not have the later model wiring.
anyone remember where this unit is?
