86 A4LD best ATF?
Tex
Since my warranty ran out when the first bush was in office, what is the best ATF and/or additives to stick in my A4LD automatic?
The modern versions of this transmission (5R55E, 5R44E) use Mercon V, but I can't say for sure if that's what will work best in your transmission. Mercon V wasn't around until about a decade after your transmission was built.
I would guess that Mercon V would be okay to use in this transmission, but you may want to play it safe and just use a Dex/Merc fluid. Something like MaxLife Dex/Merc would probably be good.
Ford might have also spec'd different friction materials on certain parts depending on wether or not you are running merc5 or regular merc fluids. I know some of the Taurus transmissions are like that...... the A4LD and its variants might be as well.
I looked on Alldata it shows a TSB that says use Mercon V. So the least expensive supertech stuff should be good.
TSB 06-14-4
07/24/06
MERCON ATF IS BEING REPLACED BY MERCON V
ATF AS A SERVICE FLUID.
FORD:
1980-1997 Crown Victoria
1981-1997 Mustang, Thunderbird
1981-2003 Escort
1986-1993 Festiva
1986-1997 Taurus
1989-1997 Probe
1994-1997 Aspire
1995-2000 Contour
1980-1996 Bronco
1981-2003 F-150
1981-2004 E-Series, F-Super Duty
1983-1996 Ranger
1986-1996 Aerostar
1991-1997 Explorer
1993-2004 F-53 Motorhome Chassis
1995-1998 Windstar
1997-2004 Expedition
2000-2005 Excursion
2001-2007 Escape
1987-2000 F-B-Series
2000-2007 F-650, F-750
LINCOLN:
1980-1997 Town Car
1981-1997 Continental
1993-1997 Mark VIII
1998-2004 Navigator
2002-2003 Blackwood
MERCURY:
1980-1997 Grand Marquis
1981-1997 Cougar
1986-1997 Sable
1987-1999 Tracer
1995-2000 Mystique
1999-2002 Cougar
1993-2002 Villager
1997 Mountaineer
2005-2007 Mariner
MERKUR:
1985-1989 XR4TI
This article supersedes TSB 01-15-7 to update the vehicle application chart.
ISSUE
MERCON(R) Automatic Transmission Fluid is being replaced by MERCON(R) V as a service fluid.
