Newsflash, the POINT of posting the article is that it should actually be capable of doing the task called upon. You're saying a bit of snow is not a realistic task for an $85,000+ a AWD SUV with 20" tires, lengthy boasting about "off road" capabilities, traversing rocks, deep water, snow, sand, loose dirt, etc. should be more than capable of what we can observe from the photos? No way should it have gotten stuck, and then bricked.
This is the alleged Rivian performance capabilities, which is OBVIOUSLY now another "snow job" just like most of the false EV marketing nonsense that people really must start to see thru as top rate propaganda.
Explore the places you love with the people you love. It’s time to make some memories.
rivian.com
Drive through 3+ feet of water. Rock crawl at a 100% grade. Traverse just about any terrain with 14.9 inches of ground clearance. Tow up to 7,700 lbs. With a 0-60 mph time as quick as 3 seconds, depending on your configuration, it also delivers the on-road handling of a sports car.¹ Set your R1S for a smooth ride around town or put it in Off-Road mode for the trail. With multiple modes, you can tailor the R1S to your personal driving preferences or different road conditions.
Off-Road Rock Crawl
This mode is designed for
the most challenging off-road situations, such as climbing over rocks or steep grades. It sets the ride height to high — balancing stability with clearance — with room to go higher when you need to. Vehicles equipped with Quad-Motor AWD can also manage the torque for each wheel independently for precise, slow-speed maneuvering over rugged obstacles.
Off-Road Rally
Designed for higher off-road speeds on gravel roads, this mode activates
torque vectoring to proactively distribute power between all four wheels (front to rear only on Dual-Motor), while modifying the traction and stability control systems to provide excellent performance and control.
Off-Road Drift
This mode is for advanced drivers wanting to drift their R1S on a closed course. It uses torque vectoring to proactively distribute power between all four wheels (front to rear only on Dual-Motor), and significantly reduces traction control intervention, increasing the
fun-to-drive experience in snow, sand and loose dirt."
