i have 12 quarts of fluid to put in. do i just do a drain and fill (4 quarts), drive around the block, and do that three times? or is starting it up, running it through the gears, and shutting it off, all while its on the ramps, good enough? or should i take off the transmission cooler line and flush it like that? i saw a youtube video of someone doing that by removing the grille and disconnecting the line there...
